Use statistics to help you monitor Open Shortest Path First (OSPF) performance. You can also graph statistics for all OSPF packets transmitted by the switch.
 - Click OSPF.
 - Click the Stats tab.
 - To create a graph for OSPF statistics, select a column, and then select a graph type.
Stats Field Descriptions
Use the data in the following table to use the Stats tab.
 Name  |
 Description  |
 LsdbTblSize  |
 Specifies the number of entries in the link state database table.  |
 TxPackets  |
 Specifies the number of packets transmitted by OSPF.  |
 RxPackets  |
 Specifies the number of packets received by OSPF.  |
 TxDropPackets  |
 Specifies the number of packets dropped before being transmitted by OSPF.  |
 RxDropPackets  |
 Specifies the number of packets dropped before they are received by OSPF.  |
 RxBadPackets  |
 Specifies the number of packets received by OSPF that are bad.  |
 SpfRuns  |
 Specifies the number of SPF calculations performed by OSPF.  |
 BuffersAllocated  |
 Specifies the number of buffers allocated for OSPF.  |
 BuffersFreed  |
 Specifies the number of buffers freed by OSPF.  |
 BufferAllocFailures  |
 Specifies the number of times that OSPF has failed to allocate buffers.  |
 BufferFreeFailures  |
 Specifies the number of times that OSPF has failed to free buffers.  |
 Routes  |
 Specifies the count of OSPF routes.  |
 Adjacencies  |
 Specifies the count of OSPF adjacencies.  |
 Areas  |
 Specifies the count of OSPF areas.  |
