interface-config-radio-instance
Associates an existing global association list with this radio interface
An association ACL is a policy-based ACL that either prevents or allows wireless clients from connecting to a managed access point radio. An ACL is a sequential collection of permit and deny rules that apply to incoming and outgoing packets. When a packet is received on an interface, the controller, service platform, or access point compares the fields in the packet against the applied ACLs to verify the packet has the required permissions to be forwarded. If a packet does not meet any of the criteria specified in the ACL, it is dropped.
association-list global <GLOBAL-ASSOC-LIST-NAME>
| association-list global <GLOBAL-ASSOC-LIST-NAME> | Associates an existing global association list with this radio interface |
ap505-133E1C(config-profile-testap505-if-radio2)#association-list global test ap505-133E1C(config-profile-testap505-if-radio2)#show context interface radio2 mesh client antenna-elevation 5.0 antenna-gain 12.0 aggregation ampdu tx-only association-list global test aeroscout forward ip 1.23.4.56 port 300 antenna-mode 2x2 antenna-diversity assoc-response rssi-threshold -128 ap505-133E1C(config-profile-testap505-if-radio2)#
| no (radio-interface-config-command) | Removes the global association list associated with this radio interface |
