Publishes interface via OSPF or BGP based on Virtual Router Redundancy Protocol (VRRP) status
VRRP allows automatic assignment of available IP routers to participating hosts. This increases the availability and reliability of routing paths via automatic default gateway selections on an IP subnetwork. This option is enabled by default.
None
nx9500-6C8809(config-device-B4-C7-99-6C-88-09)#vrrp-state-check nx9500-6C8809(config-device-B4-C7-99-6C-88-09)#show context nx9000 B4-C7-99-6C-88-09 use profile default-nx9000 use rf-domain default ....................................................................... no weight no timers bgp ip default-gateway priority 7500 bgp-route-limit num-routes 10 retry-count 5 retry-timeout 60 reset-time 360 vrrp-state-check controller adopted-devices controllers alias string $SN B4C7996C8809 nx9500-6C8809(config-device-B4-C7-99-6C-88-09)#
no | Disables the publishing of an interface via OSPF/BGP based on VRRP status |
