Removes or resets this DHCP user pool‘s settings
Access Points — AP 6522, AP 6532, AP 6562, AP 7161, AP 7502, AP-7522, AP 7532, AP 81XX, AP 8232
Wireless Controllers — RFS 4000, RFS 6000
Service Platforms — NX 7500, NX 9500, NX 9510
no [address|bootfile|ddns|default-router|dns-server|domain-name|excluded-address| lease|netbios-name-server|netbios-node-type|network|next-server|option| respond-via-unicast|static-binding|static-route|update]
no [bootfile|default-router|dns-server|domain-name|lease|netbios-name-server| netbios-node-type|next-server|network|respond-via-unicast]
no address [<IP>|<HOST-ALIAS--NAME>|all]
no address range [<START-IP>|<START-HOST-ALIAS-NAME>] [<END-IP>|<END-HOST-ALIAS-NAME>]
no ddns [domainname|multiple-user-class|server|ttl]
no excluded-address [<IP|<HOST-ALIAS-NAME>]
no excluded-address range [<START-IP>|<START-HOST-ALIAS-NAME>] [<END-IP>|<END-HOST-ALIAS-NAME>]
no option <OPTION-NAME>
no static-binding client-identifier <CLIENT-IDENTIFIER>
no static-binding hardware-address <MAC>
no static-route <IP/MASK> <GATEWAY-IP>
no update dns {override}
                         no bootfile  |
                         Removes a BOOTP bootfile configuration  |
                         no default-router  |
                         Removes the configured default router for the DHCP pool  |
                         no dns-server  |
                         Removes the configured DNS server for the DHCP pool  |
                         no domain-name  |
                         Removes the configured DNS domain name  |
                         no lease  |
                         Resets the lease to its default (24 hours)  |
                         no netbios-name-server  |
                         Removes the configured NetBIOS name server  |
                         no netbios-node-type  |
                         Removes the NetBIOS node type  |
                         no next-server  |
                         Removes the next server utilized in the boot process  |
                         no network  |
                         Removes the DHCP server network information  |
                         no respond-via-unicast  |
                         Sets the DHCP offer and ACK as broadcast instead of unicast  |
no address [<IP>|HOST-ALIAS-NAME|all]
                         no address  |
                         Resets configured DHCP pool addresses  |
                         <IP>  |
                         Removes an IP address from the list of addresses  |
                         <HOST-ALIAS-NAME>  |
                         Removes the host alias (used to identify a single host) associated with this DHCP pool‘s address list  |
                         all  |
                         Removes configured DHCP IP addresses  |
                         no address  |
                         Resets the DHCP pool addresses  |
                         range [<START-IP>| <START-HOST-ALIAS- NAME>] [<END-IP>| <END-HOST-ALIAS- NAME>]  |
                         Removes a range of IP addresses and host aliases associated with this DHCP pool‘s address list.
 Note: The specified IP addresses and host aliases are removed from the DHCP pool‘s address list.  |
                         no ddns  |
                         Resets DDNS parameters  |
                         domainname  |
                         Removes DDNS domain name information  |
                         multiple-user-class  |
                         Resets the use of a multiple user class with the DDNS  |
                         server  |
                         Removes configured DDNS servers  |
                         ttl  |
                         Resets the TTL information for DDNS updates  |
no excluded-address [<IP|HOST-ALIAS-NAME>]
                         no excluded-address <IP>  |
                         Removes an excluded IP address from the list of addresses that cannot be issued by the DHCP server
                         <HOST-ALIAS-NAME>  |
                         Removes the host alias (used to identify a single host) associated with this DHCP pool‘s excluded-address list  |
no no excluded-address range [<START-IP>|<START-HOST-ALIAS-NAME>] [<END-IP>|<END-HOST-ALIAS-NAME>]
                         no excluded-address  |
                         Removes a range of excluded IP addresses from the list of addresses that cannot be issued by the DHCP server  |
                         range [<START-IP>|<START- HOST-ALIAS-NAME>] [<END-IP> <END-HOST-ALIAS- NAME>]  |
                         Removes a range of IP addresses and host aliases associated with this DHCP pool‘s excluded address list. <START-IP> – Specify the first IP address in the range.
                         no option  |
                         Resets DHCP option information  |
                         <OPTION-NAME>  |
                         Defines the DHCP option  |
                         no static-binding  |
                         Removes static bindings for DHCP client  |
                         client-identifier <CLIENT-IDENTIFIER>  |
                         Resets client identifier information
                         no static-binding  |
                         Removes static bindings for a DHCP client  |
                         hardware-address <MAC>  |
                         Resets information based on the hardware address
                         no static-route  |
                         Removes static routes for this DHCP pool  |
                         <IP/MASK>  |
                         Removes routing information for a particular subnet  |
                         <GATEWAY-IP>  |
                         Removes the gateway information from a particular subnet‘s routing information  |
                         no update dns  |
                         Removes DDNS settings  |
                         override  |
The following example shows the DHCP pool settings before the ‘no‘ commands are executed:
<exsw5>(config-dhcp-policy-test-pool-testPool)#show context
 dhcp-pool testPool
  network 192.168.13.0/24
  address 192.168.13.4 class dhcpclass1
  lease 100 23 59 59
  ddns server 192.168.13.9
  ddns domainname WID
  ddns multiple-user-class
  excluded-address range 192.168.13.25 192.168.13.28
  domain-name documentation
  netbios-node-type b-node
  bootfile test.txt
            default-router 192.168.13.8 192.168.13.9
  dns-server 192.168.13.19
  netbios-name-server 192.168.13.25
  next-server 192.168.13.26
         <exsw5>(config-dhcp-policy-test-pool-testPool)#no bootfile <exsw5>(config-dhcp-policy-test-pool-testPool)#no network <exsw5>(config-dhcp-policy-test-pool-testPool)#no default-router <exsw5>(config-dhcp-policy-test-pool-testPool)#no next-server <exsw5>(config-dhcp-policy-test-pool-testPool)#no domain-name <exsw5>(config-dhcp-policy-test-pool-testPool)#no ddns domainname <exsw5>(config-dhcp-policy-test-pool-testPool)#no lease
The following example shows the DHCP pool settings after the ‘no‘ commands are executed:
<exsw5>(config-dhcp-policy-test-pool-testPool)#show context dhcp-pool testPool address 192.168.13.4 class dhcpclass1 ddns server 192.168.13.9 ddns multiple-user-class excluded-address range 192.168.13.25 192.168.13.28 netbios-node-type b-node dns-server 192.168.13.19 netbios-name-server 192.168.13.25 <exsw5>(config-dhcp-policy-test-pool-testPool)#
                         Configures the DHCP server‘s IP address pool  |
                         Configures the BOOTP boot file path  |
                         Configures DDNS for use with this DHCP pool  |
                         Configures default routers for this DHCP pool  |
                         Configures default DNS servers for this DHCP pool  |
                         Configures the DDNS domain name for this DHCP pool  |
                         Configures IP addresses assigned as static addresses  |
                         Configures the DHCP lease settings  |
                         Configures the NetBIOS name server  |
                         Configures the NetBIOS node type  |
                         Configures the DHCP server‘s network settings  |
                         Configures the next server in the BOOTP boot process  |
                         Configures the DHCP option  |
                         Configures how a DHCP request and ACK are sent  |
                         Configure static binding information  |
                         Configures static routes installed on DHCP clients  |
                         Controls DDNS service usage  |
