A firewall protects a network from attacks and unauthorized access from outside the network. Simultaneously, it allows authorized users to access required resources. Firewalls work on multiple levels. Some work at layers 1, 2 and 3 to inspect each packet. The packet is either passed, dropped or rejected based on rules configured on the firewall.
Firewalls use application layer filtering to enforce compliance. These firewalls can understand applications and protocols and can detect if an unauthorized protocol is being used, or an authorized protocol is being abused in any malicious way.
The third set of firewalls, ‘Stateful Firewalls‘, consider the placement of individual packets within each packet in the series of packets being transmitted. If there is a packet that does not fit into the sequence, it is automatically identified and dropped.
Use (config) instance to configure firewall policy commands. To navigate to the config-fw-policy instance, use the following commands:
<DEVICE>(config)#firewall-policy <POLICY-NAME>
nx9500-6C8809(config)#firewall-policy test nx9500-6C8809(config-fw-policy-test)#? Firewall policy Mode commands: acl-logging Log on flow creating traffic alg Enable ALG clamp Clamp value dhcp-offer-convert Enable conversion of broadcast dhcp offers to unicast dns-snoop DNS Snooping firewall Configure global firewall flow Firewall flow ip Internet Protocol (IP) ip-mac Action based on ip-mac table ipv6 Internet Protocol version 6 (IPv6) ipv6-mac Action based on ipv6-mac table logging Firewall enhanced logging no Negate a command or set its defaults proxy-arp Enable generation of ARP responses on behalf of another device proxy-nd Enable generation of ND responses (for IPv6) on behalf of another device stateful-packet-inspection-l2 Enable stateful packet inspection in layer2 firewall storm-control Storm-control virtual-defragmentation Enable virtual defragmentation for IPv4 and IPv6 packets (recommended for proper functioning of firewall) clrscr Clears the display screen commit Commit all changes made in this session do Run commands from Exec mode end End current mode and change to EXEC mode exit End current mode and down to previous mode help Description of the interactive help system revert Revert changes service Service Commands show Show running system information write Write running configuration to memory or terminal nx9500-6C8809(config-fw-policy-test)#
