access-type
Defines the captive portal‘s access type. The authentication scheme configured here is applied to wireless clients requesting captive portal guest access to the WiNG network.
Syntax
access-type [custom-auth-radius|logging|no-auth|radius|registration]
Parameters
custom-auth-radius
Specifies the custom user information used for authentication (RADIUS lookup of given information, such as name, e-mail address, telephone, etc.). When configured, accessing clients are required to provide a 1-32 character lookup data string used to authenticate their credentials.
When selecting this option, use the custom-auth command to configure the required user information.
logging
Enables logging of user access details.
no-auth
Defines no authentication required for a guest. Requesting clients are redirected to the captive portal Welcome page without authentication.
radius
Enables RADIUS authentication for wireless clients. A requesting client‘s user credentials require authentication before access to the captive portal is permitted. This is the default setting.
registration Enables captive portal‘s clients to self register. When enabled, a requesting client‘s user credentials require authentication locally or through social media credential exchange and validation.
If enabled, use the webpage > internal > registration > field command to customize the registration page. If not customized, the default, built-in registration Web page is displayed.
nx9500-6C8809(config-captive-portal-test)#access-type logging
nx9500-6C8809(config-captive-portal-test)#show context
captive-portal test
 access-type logging
 access-time 35
Related Commands
no
Removes the captive portal access type or reverts to default (radius)
