channel
interface-config-radio-instance
Configures a radio‘s channel of operation
Only a trained installation professional should define the radio channel. Select Smart for the radio to scan non-overlapping channels listening for beacons from other access points. After the channels are scanned, the radio selects the channel with the fewest access points. In case of multiple access points on the same channel, it selects the channel with the lowest average power level.
Channels with a “w” appended to them are unique to the 40 MHz band. Channels with a “ww” appended to them are 802.11ac specific, and appear only when using an and are unique to the 80 MHz band.
Syntax
channel [smart|acs|random|1|2|3|4|---------128www]
Parameters
channel [smart|acs|random|1|2|3|4|---------128www ]
channel Configures a radio‘s channel of operation
[smart|acs|random||1|2|3|4|------ 128www] Configures the radio‘s channel of operation, using one of the following options:
  • smart – Enables Smart RF the channel assignment for the selected radio (uses uniform spectrum spreading if Smart RF is not enabled). This is the default setting.
  • acs – Uses automatic channel selection (ACS) to assign a channel
  • random – Randomly assigns a channel
  • 1 – Sets channel 1 in 20 MHz mode as the selected radio's channel of operation
  • 2 – Sets channel 2 in 20 MHz mode as the selected radio's channel of operation
  • 3 – Sets channel 3 in 20 MHz mode as the selected radio's channel of operation
nx9500-6C8809(config-profile-510TestProfile-if-radio1)#channel 1
nx9500-6C8809(config-profile-510TestProfile-if-radio1)#show context
 interface radio1
  channel 1
  beacon period 50
  beacon dtim-period bss 1 5
  beacon dtim-period bss 2 2
  beacon dtim-period bss 14 5
  beacon dtim-period bss 15 5
  beacon dtim-period bss 16 5
  antenna-gain 12.0
  aggregation ampdu tx-only
  aeroscout forward
  antenna-mode 2x2
  antenna-diversity
--More--
Related Commands
no (radio-interface-config-command) Resets a radio‘s channel of operation
