ex3500
Displays EX3500-related statistical data
- Service Platforms — NX 75XX, NX 95XX, NX 96XX
Syntax
show ex3500 [dir|interfaces|system|upgrade|version|whichboot]
show ex3500 dir {boot-rom|config|on|opcode} {<FILE-NAME>}
{on <EX3500-DEVICE-NAME>}
show ex3500 interfaces counters [ether-like stats|ethernet <1-1> <1-52>|
ext-if-table stats|if-table stats|portUtil stats|rmon stats]
show ex3500 [system|upgrade|version|whichboot]
Parameters
ex3500 dir |
Displays EX3500 directory information based on the
option selected. The options are: boot-rom, config, opcode Note: If none of the specified options is
selected, all EX3500 system-related information is
displayed.
boot-rom |
Optional. Displays only the Boot-ROM information |
config |
Optional. Displays only the configuration file |
opcode |
Optional. Displays only the run-time operation code |
<FILE-NAME> |
Displays the contents of a specified file identified by the <FILE-NAME>
keyword. This is the name of configuration file or code image. |
on <EX3500-DEVICE-NAME> |
Optional. Executes the command on a specified EX3500
device
- <DEVICE-NAME> – Specify
the device‘s name.
ex3500 interfaces counters |
Displays EX3500 interface counters based on the option
selected. The options are: ether-like, ethernet,
ext-if-table, if-table,
portUtil, rmon |
ether-like stats |
Displays Managed Information Base (MIB) object statistics for
Ethernet-like interfaces |
ethernet <1-1> <1-52> |
Displays the Ethernet port statistics based on the unit
identifier and port number selected
- <1-1> – Specify the EX3500 unit‘s identifier from 1 - 1.
- <1-52> – Specify the
port number from 1 - 52. This range varies for the EX3524 (1-28) and EX3548 (1-52)
devices.
Note: This option displays the following for the selected Ethernet interface:
extended interface table stats, interface table stats, port utilization
information, and remote monitoring stats.
ext-if-table stats |
Displays only the extended interface table
statistics |
if-table stats |
Displays only the interface table statistics |
portUtil stats |
Displays only the port utilization information |
rmon stats |
Displays only remote monitoring (RMon) statistics |
device
the device‘s name.
show ex3500 [system|upgrade|version|whichboot] {on <EX3500-DEVICE-NAME>}
ex3500 |
Displays the following information for a specified EX3500 device or all EX3500 devices in the managed
network |
system |
Displays EX3500 system information, such as device
description, OID string, up time, name, location, contact, MAC address, etc. Some of
these information (example, system name) are configurable items, and if not
configured are left blank. |
upgrade |
Displays the opcode upgrade configuration settings |
version |
Displays hardware and software version information for a EX3500 system |
whichboot |
Displays boot information |
device
the device‘s name.
nx9500-6C8809#show ex3500 interfaces counters ethernet 1 17
Ethernet 1/ 17
===== IF table Stats =====
2166458 Octets Input
14734059 Octets Output
14707 Unicast Input
19806 Unicast Output
0 Discard Input
0 Discard Output
0 Error Input
0 Error Output
0 Unknown Protocols Input
0 QLen Output
===== Extended Iftable Stats =====
23 Multi-cast Input
5525 Multi-cast Output
170 Broadcast Input
11 Broadcast Output
===== Ether-like Stats =====
0 Alignment Errors
0 FCS Errors
0 Single Collision Frames
0 Multiple Collision Frames
0 SQE Test Errors
0 Deferred Transmissions
0 Late Collisions
0 Excessive Collisions
0 Internal Mac Transmit Errors
0 Internal Mac Receive Errors
0 Frames Too Long
0 Carrier Sense Errors
0 Symbol Errors
0 Pause Frames Input
0 Pause Frames Output
===== RMON Stats =====
0 Drop Events
16900558 Octets
40243 Packets
170 Broadcast PKTS
23 Multi-cast PKTS
0 Undersize PKTS
0 Oversize PKTS
0 Fragments
0 Jabbers
0 CRC Align Errors
0 Collisions
21065 Packet Size <= 64 Octets
3805 Packet Size 65 to 127 Octets
2448 Packet Size 128 to 255 Octets
797 Packet Size 256 to 511 Octets
2941 Packet Size 512 to 1023 Octets
9187 Packet Size 1024 to 1518 Octets
===== Port Utilization (recent 300 seconds) =====
0 Octets Input in kbits per second
0 Packets Input per second
0.00 % Input Utilization
0 Octets Output in kbits per second
0 Packets Output per second
0.00 % Output Utilization
nx9500-6C8809#
