weight (bgp-neighbor-config)
    Configures a weight for all routes
      learned from this BGP neighbor. Weight is used to decide the preferred route when the same
      route is learned from multiple neighbors. The highest weight is always chosen.
        - Service Platforms — NX9500, NX9600
    Parameters
      weight <0-65535>
              | weight <0-65535> |
              Specifies a relative weightage for all routes learned
                from this neighbor
                  - <0-65535> – Specify a value from 0 - 65535.
      nx9500-6C8809(config-profile testNX9000-router-bgp-neighbor-192.168.13.99)#
weight 10
      nx9500-6C8809(config-profile testNX9000-router-bgp-neighbor-192.168.13.99)#show context
  bgp neighbor 192.168.13.99
   remote-as 100
   advertisement-interval 100
   peer-group eBGPPeerGrp1
   port 21
   strict-capability-match
   timers connect 20
   timers 20 40
   allowas-in 10
   attribute-unchanged as-path
   capability orf prefix-list both
   default-originate
   description neighbor "This neighbor is an external AS neighbor"
   disable-connected-check
   dont-capability-negotiate
   ebgp-multihop 20
   enforce-multihop
   local-as 20 no-prepend
   maximum-prefix 400 50 warning-only
   next-hop-self
   override-capability
   passive
   password neighbor eBGPneighbor@300
   remove-private-as
   route-server-client
   send-community both
   update-source 192.168.13.1
   weight 10
