shutdown
interface-config-vlan-instance
Shuts down the selected interface. Use the no shutdown command to enable an interface.
Syntax
shutdown
Parameters
None
nx9500-6C8809(config-profile-default-nx5500-if-vlan8)#shutdown
nx9500-6C8809(config-profile-default-nx5500-if-vlan8)#show context
 interface vlan8
  ip address 10.0.0.1/8
  ip helper-address 172.16.10.3
  shutdown
Related Commands
no Disables or reverts interface VLAN settings to their default
