routing-policy-commands
The following table summarizes routing policy configuration mode commands:
Table 1. Routing-Policy-Config Commands
Command Description
apply-to-local-packets Enables PBR for locally generated packets
logging Enables logging for a specified route map
route-map Creates a route map entry
use Defines default settings to use
no (routing-policy-config-mode-command) Negates a command or sets its defaults
For more information on common commands (clrscr, commit, help, revert, service, show, write, and exit), see Common Commands.
The input parameter <HOSTNAME>, wherever used in syntaxes across this chapter, cannot include an underscore (_) character. In other words, the name of a device cannot contain an underscore.
