Configures IP components
ip [dos|tcp]
ip dos {ascend|broadcast-multicast-icmp|chargen|fraggle|ftp-bounce|invalid-protocol|
ip-ttl-zero|ipspoof|land|option-route|router-advt|router-solicit|smurf|snork|tcp-bad-sequence|
tcp-fin-scan|tcp-intercept|tcp-max-incomplete|tcp-null-scan|tcp-post-syn|tcp-sequence-past-window|
tcp-xmas-scan|tcphdrfrag|twinge|udp-short-hdr|winnuke}
ip-ttl-zero|ipsproof|land|option-route|router-advt|router-solicit|smurf|snork|tcp-bad-sequence|
tcp-fin-scan|tcp-intercept|tcp-null-scan|tcp-post-scan|tcp-sequence-past-window|tcp-xmas-scan|
tcphdrfrag|twinge|udp-short-hdr|winnuke} [log-and-drop|log-only] log-level [<0-7>|alerts|critical|
debugging|emergencies|errors|informational|notifications|warnings]
tcphdrfrag|twinge|udp-short-hdr|winnuke} [drop-only]
         ip dos tcp-max-incomplete [high|low] <1-1000>
ip tcp [adjust-mss|optimize-unnecessary-resends|recreate-flow-on-out-of-state-syn| validate-icmp-unreachable|validate-rst-ack-number|validate-rst-seq-number]
ip tcp adjust-mss <472-1460>
ip tcp [optimize-unnecessary-resends|recreate-flow-on-out-of-state-syn|validate-icmp-unreachable| validate-rst-ack-number|validate-rst-seq-number]
log-level [<0-7>|alerts|critical|debug|emergencies|errors|informational|notifications|warnings]
                         dos  |
                         Identifies IP events as DoS events  |
                         ascend  |
                         Optional. Detects ASCEND DoS attacks Ascend DoS attacks target known vulnerabilities in various versions of Ascend routers. Ascend routers listen on UDP port 9 for packets from Ascend's Java Configurator. Sending a formatted packet to this port can cause an Ascend router to crash.  |
                         broadcast-multicast-icmp  |
                         Optional. Detects broadcast or multicast ICMP Dos attacks Broadcast or multicast ICMP DoS attacks take advantage of ICMP behavior in response to echo replies. These attacks spoof the source address of the target and send ICMP broadcast or multicast echo requests to the rest of the network, flooding the target machine with replies.  |
                         chargen  |
                         Optional. Detects Chargen attacks The chargen (Character Generation Protocol) is an IP suite service primarily used for testing and debugging networks. It is also used as a source of generic payload for bandwidth and QoS measurements. The Chargen attack establishes a Telnet connection to port 19 and attempts to use the character generator service to create a string of characters which is then directed to the DNS service on port 53 to disrupt DNS services.  |
                         fraggle  |
                         Optional. Detects Fraggle DoS attacks The Fraggle DoS attack uses a list of broadcast addresses to send spoofed UDP packets to each broadcast address' echo port (port 7). Each of those addresses that have port 7 open will respond to the request generating a lot of traffic on the network. For those that do not have port 7 open they will send an unreachable message back to the originator, further clogging the network with more traffic.  |
                         ftp-bounce  |
                         Optional. Detects FTP bounce attacks A FTP bounce attack is a MIM attack that enables an attacker to open a port on a different machine using FTP. FTP requires that when a connection is requested by a client on the FTP port (21), another connection must open between the server and the client. To confirm, the PORT command has the client specify an arbitrary destination machine and port for the data connection. This is exploited by the attacker to gain access to a device that may not be the originating client.  |
                         invalid-protocol  |
                         Optional. Enables a check for an invalid protocol number Attackers may use vulnerability in the endpoint implementation by sending invalid protocol fields, or may misuse the misinterpretation of endpoint software. This can lead to inadvertent leakage of sensitive network topology information, call hijacking, or a DoS attack.  |
                         ip-ttl-zero  |
                         Optional. Enables a check for the TCP/IP TTL field having a value of zero (0) The TCP IP TTL Zero DoS attack sends spoofed multicast packets onto the network which have a TTL (Time to Live) of 0. This causes packets to loop back to the spoofed originating machine, and can cause the network to overload.  |
                         ipsproof  |
                         Optional. Enables a check for the IP spoofing DoS attack IP Spoof is a category of DoS attack that sends IP packets with forged source addresses. This can hide the identity of the attacker.  |
                         land  |
                         Optional. Detects LAND DoS attacks A LAND (Local Area Network Denial) is a DoS attack where IP packets are spoofed and sent to a device where the source IP and destination IP of the packet are the target device's IP, and similarly, the source port and destination port are open ports on the same device. This causes the attacked device to reply to itself continuously.  |
                         option-route  |
                         Optional. Enables an IP Option Record Route DoS check  |
                         router-advt  |
                         Optional. Detects router-advertisement attacks This attack uses ICMP to redirect the network router function to some other host. If that host can not provide router services, a DoS of network communications occurs as routing stops. This can also be modified to single out a specific system, so that only that system is subject to attack (because only that system sees the 'false' router). By providing router services from a compromised host, the attacker can also place themselves in a man-in-the-middle situation and take control of any open channel at will (as mentioned earlier, this is often used with TCP packet forgery and spoofing to intercept and change open TELNET sessions).  |
                         router-solicit  |
                         Optional. Detects router solicitation attacks The ICMP router solicitation scan is used to actively find routers on a network. A hacker could set up a protocol analyzer to detect routers as they broadcast routing information on the network. In some instances, however, routers may not send updates. For example, if the local network does not have other routers, the router may be configured to not send routing information packets onto the local network. ICMP offers a method for router discovery. Clients send ICMP router solicitation multicasts onto the network, and routers must respond (as defined in RFC 1122). (For more information about the process of ICMP router solicitation, see "Routing Sequences for ICMP.") By sending ICMP router solicitation packets (ICMP type 9) on the network and listening for ICMP router discovery replies (ICMP type 10), hackers can build a list of all of the routers that exist on a network segment. Hackers often use this scan to locate routers that do not reply to ICMP echo requests.  |
                         smurf  |
                         Optional. In this attack, a large number of ICMP echo packets are sent with a spoofed source address. This causes the device with the spoofed source address to be flooded with a large number of replies.  |
                         snork  |
                         Optional. This attack causes a remote Windows™ NT to consume 100% of the CPU's resources. This attack uses a UDP packet with a destination port of 135 and a source port of 7, 9, or 135. This attack can also be exploited as a bandwidth consuming attack.  |
                         tcp-bad-sequence  |
                         Optional. A DoS attack that uses a specially crafted TCP packet to cause the targeted device to drop all subsequent network traffic for a specific TPC connection.  |
                         tcp-fin-scan  |
                         Optional. Detects TCP FIN scan attacks Hackers use the TCP FIN scan to identify listening TCP port numbers based on how the target device reacts to a transaction close request for a TCP port (even though no connection may exist before these close requests are made). This type of scan can get through basic firewalls and boundary routers that filter on incoming TCP packets with the Finish (FIN) and ACK flag combination. The TCP packets used in this scan include only the TCP FIN flag setting. If the target device's TCP port is closed, the target device sends a TCP RST packet in reply. If the target device's TCP port is open, the target device discards the FIN and sends no reply.  |
                         tcp-intercept  |
                         Optional. Prevents TCP intercept attacks by using TCP SYN cookies A SYN-flooding attack occurs when a hacker floods a server with a barrage of requests for connection. Because these messages have unreachable return addresses, the connections cannot be established. The resulting volume of unresolved open connections eventually overwhelms the server and can cause it to deny service to valid requests, thereby preventing legitimate users from connecting to a Web site, accessing email, using FTP service, and so on. The TCP intercept feature helps prevent SYN-flooding attacks by intercepting and validating TCP connection requests. In intercept mode, the TCP intercept software intercepts TCP SYN (synchronization ) packets from clients to servers that match an extended access list. The software establishes a connection with the client on behalf of the destination server, and if successful, establishes the connection with the server on behalf of the client and knits the two half-connections together transparently. Thus, connection attempts from unreachable hosts will never reach the server. The software continues to intercept and forward packets throughout the duration of the connection. The number of SYNs per second and the number of concurrent connections proxied depends on the platform, memory, processor, and other factors. In the case of illegitimate requests, the software's aggressive timeouts on half-open connections and its thresholds on TCP connection requests protect destination servers while still allowing valid requests. When establishing a security policy using TCP intercept, you can choose to intercept all requests or only those coming from specific networks or destined for specific servers. You can also configure the connection rate and threshold of outstanding connections. Optionally operate TCP intercept in watch mode, as opposed to intercept mode. In watch mode, the software passively watches the connection requests flowing through the router. If a connection fails to get established in a configurable interval, the software intervenes and terminates the connection attempt.  |
                         tcp-null-scan  |
                         Optional. Detects TCP NULL scan attacks Hackers use the TCP NULL scan to identify listening TCP ports. This scan also uses a series of strangely configured TCP packets, which contain a sequence number of 0 and no flags. Again, this type of scan can get through some firewalls and boundary routers that filter incoming TCP packets with standard flag settings. If the target device's TCP port is closed, the target device sends a TCP RST packet in reply. If the target device's TCP port is open, the target discards the TCP NULL scan, sending no reply.  |
                         tcp-post-syn  |
                         Optional. Detects TCP post SYN DoS attacks A remote attacker may be attempting to avoid detection by sending a SYN frame with a different sequence number than the original SYN. This can cause an Intrusion Detection System (IDS) to become unsynchronized with the data in a connection. Subsequent frames sent during the connection are ignored by the IDS.  |
                         tcp-sequence-past- window  |
                         Optional. Enables a TCP SEQUENCE PAST WINDOW DoS attack check. Disable this check to work around a bug in Windows XP's TCP stack which sends data past the window when conducting a selective ACK.  |
                         tcp-xmas-scan  |
                         Optional. A TCP XMAS scan finds services on ports. A closed port returns a RST. This allows the attacker to identify open ports  |
                         tcphdrfrag  |
                         Optional. A DoS attack where the TCP header spans IP fragments  |
                         twinge  |
                         Optional. A twinge attack is a flood of false ICMP packets to try and slow down a system  |
                         udp-short-hdr  |
                         Optional. Enables the identification of truncated UDP headers and UDP header length fields  |
                         winnuke  |
                         Optional. This DoS attack is specific to Windows™ 95 and Windows™ NT. The WINNUKE DoS attack sends a large amount of data to UDP port 137 to crash the NETBIOS service on windows and results in high CPU utilization on the target machine.  |
                         log-and-drop  |
                         Logs the event and drops the packet  |
                         log-only  |
                         Logs the event only, the packet is not dropped  |
                         log-level  |
                         Configures the log level  |
                         <0-7>  |
                         Sets the numeric logging level  |
                         emergencies  |
                         Numerical severity 0. System is unusable  |
                         alerts  |
                         Numerical severity 1. Indicates a condition where immediate action is required  |
                         critical  |
                         Numerical severity 2. Indicates a critical condition  |
                         errors  |
                         Numerical severity 3. Indicates an error condition  |
                         warnings  |
                         Numerical severity 4. Indicates a warning condition  |
                         notification  |
                         Numerical severity 5. Indicates a normal but significant condition  |
                         informational  |
                         Numerical severity 6. Indicates a informational condition  |
                         debugging  |
                         Numerical severity 7. Debugging messages  |
                         dos  |
                         ascend  |
                         Optional. Enables an ASCEND DoS check. Ascend routers listen on UDP port 9 for packets from Ascend's Java Configurator. Sending a formatted packet to this port can cause an Ascend router to crash.  |
                         broacast-multicast-icmp  |
                         Optional. Detects broadcast or multicast ICMP packets as an attack  |
                         chargen  |
                         Optional. The chargen (Character Generation Protocol) is an IP suite service primarily used for testing and debugging networks. It is also used as a source of generic payload for bandwidth and QoS measurements.  |
                         fraggle  |
                         Optional. A Fraggle DoS attack checks for UDP packets to or from port 7 or 19  |
                         ftp-bounce  |
                         Optional. A FTP bounce attack is a MIM attack that enables an attacker to open a port on a different machine using FTP. FTP requires that when a connection is requested by a client on the FTP port (21), another connection must open between the server and the client. To confirm, the PORT command has the client specify an arbitrary destination machine and port for the data connection. This is exploited by the attacker to gain access to a device that may not be the originating client.  |
                         invalid-protocol  |
                         Optional. Enables a check for invalid protocol number  |
                         ip-ttl-zero  |
                         Optional. Enables a check for the TCP/IP TTL field having a value of zero (0)  |
                         ipsproof  |
                         Optional. Enables a check for IP spoofing DoS attack  |
                         land  |
                         Optional. A LAND (Local Area Network Denial) is a DoS attack where IP packets are spoofed and sent to a device where the source IP and destination IP of the packet are the target device's IP, and similarly, the source port and destination port are open ports on the same device. This causes the attacked device to reply to itself continuously.  |
                         option-route  |
                         router-advt  |
                         Optional. This is an attack, where a default route entry is added remotely to a device. This route entry is given preference, and thereby exposes an attack vector.  |
                         router-solicit  |
                         Optional. Router solicitation messages are sent to locate routers as a form of network scanning. This information can then be used to attack a device.  |
                         smurf  |
                         snork  |
                         tcp-bad-sequence  |
                         Optional. A DoS attack that uses a specially crafted TCP packet to cause the targeted device to drop all subsequent network traffic for a specific TPC connection  |
                         tcp-fin-scan  |
                         Optional. A FIN scan finds services on ports. A closed port returns a RST. This allows the attacker to identify open ports.  |
                         tcp-intercept  |
                         Optional. Prevents TCP intercept attacks by using TCP SYN cookies  |
                         tcp-null-scan  |
                         Optional. A TCP null scan finds services on ports. A closed port returns a RST. This allows the attacker to identify open ports  |
                         tcp-post-syn  |
                         Optional. Enables a TCP post SYN DoS attack  |
                         tcp-xmas-scan  |
                         Optional. A TCP XMAS scan finds services on ports. A closed port returns a RST. This allows the attacker to identify open ports.  |
                         tcphdrfrag  |
                         twinge  |
                         udp-short-hdr  |
                         winnuke  |
                         Optional. This DoS attack is specific to Windows™ 95 and Windows™ NT, causing devices to crash with a blue screen  |
                         drop-only  |
                         Optional. Drops a packet without logging  |
                         dos  |
                         tcp-max-incomplete  |
                         Sets the limits for the maximum number of incomplete TCP connections  |
                         high  |
                         Sets the upper limit for the maximum number of incomplete TCP connections  |
                         low  |
                         Sets the lower limit for the maximum number of incomplete TCP connections  |
                         <1-1000>  |
                         Sets the range limit from 1 - 1000 connections  |
                         tcp  |
                         Identifies and configures TCP events and configuration items  |
                         adjust-mss  |
                         Adjusts the TCP MSS. Use this option to adjust the MSS for TCP segments on the router.  |
                         <472-1460>  |
                         Sets the TCP MSS value from 472 - 1460 bytes. The default is 472 bytes.  |
ip tcp [optimize-unnecessary-resends|recreate-flow-on-out-of-state-syn| validate-icmp-unreachable|validate-rst-ack-number|validate-rst-seq-number]
                         tcp  |
                         optimize-unnecessary- resends  |
                         Enables the validation of unnecessary TCP packets  |
                         recreate-flow-on-out-of-state-sync  |
                         Allows a TCP SYN packet to delete an old flow in TCP_FIN_FIN_STATE, and TCP_CLOSED_STATE states and create a new flow  |
                         validate-icpm- unreachable  |
                         Enables the validation of the sequence number in ICMP unreachable error packets, which abort an established TCP flow  |
                         validate-rst-ack-number  |
                         Enables the validation of the acknowledgment number in RST packets, which abort a TCP flow  |
                         validate-rst-seq-number  |
                         Enables the validation of the sequence number in RST packets, which abort an established TCP flow  |
nx9500-6C8809(config-fw-policy-testFW)#ip dos fraggle drop-only
         nx9500-6C8809(config-fw-policy-testFW)#ip dos tcp-max-incomplete high 600
         nx9500-6C8809(config-fw-policy-testFW)#ip dos tcp-max-incomplete low 60
         nx9500-6C8809(config-fw-policy-testFW)#ip dos tcp-sequence-past-window drop-only
         nx9500-6C8809(config-fw-policy-testFW)#show context firewall-policy testFW ip dos fraggle drop-only ip dos tcp-sequence-past-window drop-only ip dos tcp-max-incomplete high 600 ip dos tcp-max-incomplete low 60 flow timeout icmp 16000 flow timeout udp 10000 flow timeout tcp established 1500 flow timeout other 16000 dhcp-offer-convert alg facetime dns-snoop entry-timeout 1200 nx9500-6C8809(config-fw-policy-testFW)#
| no |
                         Resets firewall policy IP components  |
