logout-fqdn
the Logout FQDN as the FQDN address to logout of the captive portal session from the client (for example, logout.guest.com).
Syntax
logout-fqdn <WORD>
Parameters
logout-fqdn <WORD>
logout-fqdn <WORD>
Configures the FQDN address used to logout
  • <WORD> – Provide the FQDN address (for example, logout.guestaccess.com).
rfs4000-229D58(config-captive-portal-test)#logout-fqdn logout.testuser.com
rfs4000-229D58(config-captive-portal-test)#show context
captive-portal test
Related Commands
no
Clears the logout FQDN address
