virtual-machine
Displays the virtual-machine (VM) configuration, logs, and statistics
Syntax
show virtual-machine [configuration|debugging|export|statistics]
show virtual-machine [configuration|statistics] {<VM-NAME>|team-urc|team-rls|
team-vowlan} {(on <DEVICE-NAME>)}
show virtual-machine debugging {level|on}
show virtual-machine debugging {level [debug|error|info|warning]} {on <DEVICE-NAME>}
show virtual-machine export <VM-NAME> {on <DEVICE-NAME>}
show virtual-machine [configuration|statistics] {<VM-NAME>|adsp|team-cmt}
Parameters
virtual-machine Displays the following VM-related information: configuration or statistics
configuration Displays detailed VM configuration
statistics Displays VM statistics
[<VM-NAME>| team-urc|team-rls| team-vowlan] The following keywords are common to the ‘configuration‘ and ‘statistics‘ parameters:
  • VM-NAME> – Optional. Displays VM configuration or statistics for the virtual machine identified by the <VM-NAME> keyword. Specify the VM name.
  • team-urc – Optional. Displays TEAM-URC (IP-PBX) VM configuration/statistics
  • team-rls – Optional. Displays TEAM-RLS (Radio Link Server) VM configuration/statistics<
  • team-vowlan – Optional. Displays TEAM-VoWLAN (Voice over WLAN) VM configuration/statistics
on <DEVICE-NAME> Specifies the name of the device on which the command is executed
  • <DEVICE-NAME> – Specify the name of the service platform.
[<VM-NAME>|adsp| team-cmt] The following keywords are common to the ‘configuration‘ and ‘statistics‘ parameters:
  • adsp – Optional. Displays Air-Defense Services Platform (ADSP) VM configuration/statistics
  • team-cmt – Optional. Displays TEAM-CMT VM configuration/statistics
show virtual-machine debugging {level[debug|error|info|warning]}
{on <DEVICE-NAME>}
debugging Displays VM debugging logs
level [debug| error|info|warning] Optional. Displays VM debugging logs based on the level selected. The available options are:
  • debug – Displays VM logs of level debug and above
  • error – Displays VM logs of level error
  • info – Displays VM logs of level Info and above
  • warning – Displays logs of level warning and above
export Displays VM configuration export related information
<VM-NAME>] Displays VM configuration export related information for the virtual machine identified by the <VM-NAME> keyword. Specify the VM name.
The NX 95XX and NX 96XX series service platforms will display ADSP and TEAM-CMT VM configuration export information.
nx9500-6C874D#show virtual-machine statistics
       NAME         STATE   VCPUS MEM (MB)    BRIDGE-IF             IP
  WiNG             -         -     18432    -               -
  adsp             Halted    -     -        unknown         -
  team-cmt         Halted    -     -        unknown         -
nx9500-6C874D#
nx9500-6C874D#show virtual-machine configuration
           NAME               AUTOSTART         MEMORY(MB)          VCPUS
  WiNG                     -                 18432              -
  adsp                     ignore            12000              12
  team-cmt                 ignore            1024               1
nx9500-6C874D#
nx9500-6C874D>show virtual-machine statistics adsp
 VM name: adsp
 Base Version    : unknown
 Install Status  : not_installed
nx9500-6C874D>
