payload-size (iot-device-type-imagotag-policy)
Configures the maximum size of the payload in packets exchanged between ESL communicator and tags
Syntax
payload-size <1-32>
Parameters
payload-size <1-32>
payload-size <1-32> Configures the packet‘s payload size
  • <1-32> – Specify the value from 1 - 32 bytes. The default setting is 32 bytes.
Note: SES-Imagotags recommends NOT to change the default setting.
nx9500-6C8809(config-iot-device-type-imagotag-policy-ImagoTagPolicy)#payload-size 25
nx9500-6C8809(config-iot-device-type-imagotag-policy-ImagoTagPolicy)#show context
 iot-device-type-imagotag-policy ImagoTagPolicy
  enable
  output-power Level-B
  payload-size 25
  fcc-enable
  channel 9
Related Commands
no (iot-device-type-imagotag-policy) Reverts the payload size to default (32 bytes)
