Removes device overrides in order to enable profile settings to take effect
remove-override <PARAMETERS>
remove-override <PARAMETERS> | Removes settings configured at the device level based on the parameters passed. The profile (applied to the device) settings take effect once the device-level overrides are removed. |
nx9500-6C8809(config-device B4-C7-99-6C-88-09)#remove-override ? adopter-auto-provisioning-policy-lookup Use centralized auto-provisioning policy when adopted by another controller adoption Adoption configuration adoption-mode Configure the adoption mode for the access-points in this RF-Domain alias Alias all Remove all overrides for the device application-policy Application Policy configuration area Reset name of area where the system is located arp Address Resolution Protocol (ARP) auto-learn Auto learning autogen-uniqueid Autogenerate a unique id autoinstall Autoinstall settings bridge Bridge group commands captive-portal Captive portal cdp Cisco Discovery Protocol channel-list Configure a channel list to be advertised to wireless clients cluster Cluster configuration configuration-persistence Automatic write of startup configuration file contact The contact controller WLAN controller configuration country-code The country of operation critical-resource Critical Resource crypto Encryption related commands device-upgrade Device firmware upgrade dot1x 802.1X dpi Deep-Packet-Inspection (Application Assurance) dscp-mapping IP DSCP to 802.1p priority mapping for untagged frames email-notification Email notification configuration enforce-version Check the firmware versions of devices before interoperating environmental-sensor Environmental Sensors Configuration events System event messages export Export a file file-sync File sync between controller and adoptees firewall Enable/Disable firewall floor Reset name of floor where the system is located geo-coordinates Geo co-ordinates for this device global Remove global overrides for the device but keeps per-interface overrides gre GRE protocol interface Select an interface to configure ip Internet Protocol (IP) ipv6 Internet Protocol version 6 (IPv6) l2tpv3 L2tpv3 protocol l3e-lite-table L3e lite Table led LED on the device lldp Link Layer Discovery Protocol location The location logging Modify message logging facilities mac-address-table MAC Address Table mac-auth 802.1X memory-profile Memory-profile mint MiNT protocol mpact-server MPACT server configuration noc Noc related configuration ntp Configure NTP offline-duration Duration to mark adopted device as offline override-wlan Overrides for wlans power-config Configure power mode preferred-controller-group Controller group this system will prefer for adoption preferred-tunnel-controller Tunnel Controller Name this system will prefer for tunneling extended vlan traffic rf-domain-manager RF Domain Manager router Dynamic routing routing-policy Policy Based Routing Configuration sensor-server AirDefense WIPS sensor server configuration spanning-tree Spanning tree timezone The timezone traffic-class-mapping IPv6 traffic-class to 802.1p priority mapping for untagged frames traffic-shape Traffic shaping trustpoint Assign a trustpoint to a service tunnel-controller Tunnel Controller group this controller belongs to use Set setting to use vrrp VRRP configuration service Service Commands nx9500-6C8809(config-device B4-C7-99-6C-88-09)#
