tree-node [campus|city|country|region] {(campus|city|country|region)}
         | tree-node | Configures the hierarchical tree structure defining
                        the RF Domain‘s location. The tree node hierarchy can be
                        configured in any order, but will always appear as:
                           country > region > city >
                           campus. Further, a higher node, such as
                        country, cannot be defined under a lower node, such as
                        region. An RF Domain can be placed under any one of the
                        tree nodes. But, an RF Domain at the country level may
                        have all four nodes defined. Whereas, an RF Domain
                        restricted to a campus, cannot have the country, city,
                        and region nodes.At least one of these four nodes must be defined. This feature is disabled by default.  |
| campus | Configures the campus name for this RF Domain
| city | Configures the city for this RF Domain
| country | Configures the country for this RF Domain |
| region | Configures the region for this RF Domain |
Adding a country first is a good idea since region, city, and campus can all be added as sub-nodes in the tree structure. However, the selected country is an invalid tree node until a RF Domain is mapped.
A city and campus can be added in the tree structure as sub-nodes under a region. An RF Domain can be mapped anywhere down the hierarchy for a region and not just directly under a country. For example, a region can have city, campus, and one RF Domain mapped.
Only a campus can be added as a sub-node under a city. The city is an invalid tree node until a RF Domain is mapped somewhere within the directory tree.
A campus is the last node in the hierarchy before a RF Domain, and it is not valid unless it has a RF Domain mapped.
After creating the tree structure do a commit and save for the tree configuration to take effect and persist across reboots.
ap505-13403B(config-rf-domain-default)#tree-node campus SanJoseUniversity city SanJose country us
ap505-13403B(config-rf-domain-default)#show context rf-domain default country-code us tree-node country us city SanJose campus SanJoseUniversity ap505-13403B(config-rf-domain-default)#t
| no (rf-domain-config-mode) | Removes the RF Domain‘s tree-node configuration |
