scan-mode [Channel-Lock|Custom-Scan|Default-Scan]
scan-mode Channel-Lock lock-frequency <LOCK-FREQUENCY>
scan-mode [Custom-Scan|Default-Scan]
| scan-mode | Configures the mode of scanning used by the sensors to scan system-defined or user-defined channels for RSSI assessments. The options are: Channel-Lock, Custom-Scan, and Default-Scan. |
| Channel-Lock lock-frequency <LOCK-FREQUENCY> | Configures the mode of scanning as channel-lock
| scan-mode | Configures the mode of scanning used by the sensor. The options are: channel-lock, custom-scan, and default-scan. |
| Custom-Scan | Configures the mode of scanning as custom-scan Select this option to restrict scanning to user-defined channels. If selecting this option, use the custom-scan > channel-frequency command to configure the channels scanned by the dedicated sensor. For more information, see custom-scan.  |
| Default-Scan | Configures the mode of scanning as Default-Scan. This is the default
                  setting. By default the system has a fixed, built-in list of channels that are scanned. These channels are hard coded in a spread pattern of 1, 6, 11, 36, 40, 44, and 48. When selected, the dedicated sensor scans only these default channels.  |
nx9500-6C8809(config-sensor-policy-test)#scan-mode Custom-Scan
      nx9500-6C8809(config-sensor-policy-test)#show context sensor-policy test rssi-interval-duration 30 scan-mode Custom-Scan custom-scan channel-frequency 2412 width 20MHz scan-weight 1000 custom-scan channel-frequency 2417 width 20MHz scan-weight 1000 nx9500-6C8809(config-sensor-policy-test)#
| no (sensor-policy-config-mode-commands) | Reverts the scan-mode to default (Default-Scan) |
