This feature enables auto-shutdown of select 2.4 GHz radios, in dual-band networks, to maintain co-channel interference (CCI) levels within specified limits. When enabled, Smart-RF monitors CCI levels to ensure that the deployment average CCI remains within specified minimum and maximum CCI limits. If the deployment average CCI is found to exceed the maximum threshold value, 2.4 GHz radios, causing neighbor interference, are shut down one-by-one until the deployment average CCI falls below the maximum threshold value. The reverse process occurs when the deployment average CCI falls below the minimum threshold value. In this scenario, previously disabled radios are enabled one-by-one until the deployed average CCI reaches acceptable levels.
Use this command to enable select-shutdown and configure the maximum and minimum CCI thresholds.
select-shutdown {cci-high-threshold|cci-low-threshold|frequency|frequency-limiter}
select-shutdown {cci-high-threshold <-85--55>}
select-shutdown {cci-low-threshold <-100--55>}
select-shutdown {frequency <0-3600>}
select-shutdown {frequency-limiter <1-1000>}
select-shutdown {cci-high-threshold <-85--55>|cci-low-threshold <-100--55>|frequency <0-3600>|frequency-limiter <1-1000>}
select-shutdown | Enables auto-shutdown of selected 2.4 GHz radios to maintain the deployment average CCI levels within a specified range |
cci-high-threshold <-85--55> | Optional. Configures the maximum CCI threshold
Note: If not specified, the system uses the default value
as the upper limit.
cci-low-threshold <-100--55> | Optional. Configures the minimum CCI threshold
as the lower limit.
frequency <0-3600> | Configures the interval, in minutes, at which 2.4 GHz
radios are selected for shut down. When the deployment average CCI exceeds the
specified maximum threshold, Smart RF shuts down 2.4 GHz radios until the CCI
reaches acceptable levels. Use this option, to configure the interval between
successive radio shut down.
frequency-limiter <1-1000> | Configures the minimum multiple of Interference Recovery
frequency that the select-shutdown frequency can be set to
nx9500-6C8809(config-smart-rf-policy-testSmartRF)#select-shutdown
cci-high-threshold -55
cci-low-threshold -95
nx9500-6C8809(config-smart-rf-policy-test)#show context smart-rf-policy test group-by floor sensitivity custom assignable-power 2.4GHz max 20 assignable-power 2.4GHz min 8 channel-list 2.4GHz 1,12 channel-width 5GHz auto channel-width 2.4GHz auto area test channel-list 2.4GHz 1,2,3 avoidance-time dfs 300 interference-recovery channel-switch-delta 2.4GHz 5 neighbor-recovery power-threshold 5GHz -65 neighbor-recovery power-threshold 2.4GHz -82 select-shutdown cci-high-threshold -55 select-shutdown cci-low-threshold -95 coverage-hole-recovery snr-threshold 2.4GHz 35 nx9500-6C8809(config-smart-rf-policy-test)#
no (smart-rf-policy-config-mode-command) | Disables select-shutdown of 2.4 GHz radios and reverts the select-shutdown parameters (maximum and minimum CCI thresholds, frequency, and frequency-limiter) to default values. |
