net-auth-type [accept-terms|dns-redirect|http-redirect|online-enroll] {url <URL>}
net-auth-type |
Specifies the network authentication type used with this passpoint policy. The options are: accept-terms, dns-redirect, http-redirect, and online-enroll. |
accept-terms |
Enables user acceptance of terms and conditions |
dns-redirect |
Enables DNS redirection of user |
http-redirect |
Enables HTTP redirection of user |
online-enroll |
Enables online user enrolment |
url <URL> |
Optional. Specify the location for each of above network authentication types. |
nx9500-6C8809(config-passpoint-policy-test)#net-auth-type accept-terms url www.test.com
nx9500-6C8809(config-passpoint-policy-test)#show context passpoint-policy test access-network-type chargeable-public connection-capability ip-protocol 2 port 10 closed nai-realm example eap-method 1 ttls auth-param vendor hex 00001E eap-method 2 rsa-public-key auth-param credential cert net-auth-type accept-terms url www.test.com 3gpp mcc 505 mnc 14 nx9500-6C8809(config-passpoint-policy-test)#
no |
Removes the network authentication type configured with this passpoint policy |
