no user <USERNAME>
no user <USERNAME>
no user <USERNAME> |
Deletes a RADIUS user
The following example shows the RADIUS user pool ‘testuser‘ settings before the ‘no‘ command is executed:
nx9500-6C8809(config-radius-user-pool-wdws)#show context radius-user-pool-policy wdws user guestuser1 password 0 guestuser@1 group wdws guest expiry-time 12:30 expiry-date 12/15/2014 access-duration 500 nx9500-6C8809(config-radius-user-pool-wdws)#
nx9500-6C8809(config-radius-user-pool-wdws)#no user guestuser1
The following example shows the RADIUS user pool ‘testuser‘ settings after the ‘no‘ command is executed:
nx9500-6C8809(config-radius-user-pool-wdws)#show context radius-user-pool-policy wdws nx9500-6C8809(config-radius-user-pool-wdws)#
