wmm
Configures 802.11e WMM (wireless multi media) parameters
Syntax
wmm [background|best-effort|video|voice]
wmm [background|best-effort|video|voice] [aifsn <1-15>|cw-max <0-15>|cw-min <0-15>|
txop-limit <0-65535>]
Parameters
wmm background
Configures background access category wireless multimedia settings
wmm best-effort
Configures best effort access category wireless multimedia settings
wmm video
Configures video access category wireless multimedia settings
wmm voice
Configures voice access category wireless multimedia settings
aifsn <1-15>
Configures AIFSN (Arbitrary Inter-Frame Space Number) as the wait time between data frames derived from the AIFSN and slot time
  • background – Sets the current AIFSN for low (background) traffic. The default is 7.
  • best-effort – Sets the current AIFSN for normal (best-effort) traffic. The default is 3.
  • video – Set the current AIFSN for video traffic. Higher-priority traffic video categories should have lower AIFSNs than lower-priority traffic categories. This causes lower-priority traffic to wait longer before attempting access. The default is 1.
  • voice – Sets the current AIFSN for voice traffic. Higher-priority traffic voice categories should have lower AIFSNs than lower-priority traffic categories. This causes lower-priority traffic to wait longer before attempting access. The default is 1.
The following keyword is common to all of the above traffic types:
  • <1-15> – Sets a value from 1 - 15
cw-max <0-15>
Clients pick a number between 0 and the min contention window to wait before retransmission. Clients then double their wait time on a collision, until it reaches the maximum contention window.
  • background – Sets CW Max for low (background) traffic. The default is 10.
  • best-effort – Sets CW Max for normal (best effort) traffic. The default is 6.
  • voice – Sets CW Max for voice traffic. The default is 3.
  • video – Sets CW Max for video traffic. The default is 4
  • <0-15> – ECW: the contention window. The actual value used is (2^ECW - 1).
Lower values are used for higher priority traffic (like video and voice) and higher values are used for lower priority traffic (like background and best-effort).
cw-min <0-15>
Clients select a number between 0 and the min contention window to wait before retransmission. Clients then double their wait time on a collision, until it reaches the maximum contention window.
  • background – Sets CW Min for low (background) traffic. The default is 4.
  • best-effort – Sets CW Min for normal (best effort) traffic. The default is 4.
  • voice – Sets CW Min for voice traffic. The default is 2.
  • video – Sets CW Min for video traffic. The default is 3.
Set the interval, in microseconds, during which a particular client has the right to initiate transmissions
  • background – Sets TXOP for low (background) traffic. The default is 0.
  • best-effort – Sets TXOP for normal (best effort) traffic. The default is 4.
  • voice – Sets TXOP for voice traffic. The default is 47.
  • video – Sets TXOP for video traffic. The default is 94.
  • <0-65535> – Specify a value from 0 - 65535 to configure the transmit opportunity limit in 32 microsecond units.
Usage Guidelines
Before defining a radio QoS policy, refer to the following deployment guidelines to ensure the configuration is optimally effective:
nx9500-6C8809(config-radio-qos-test)#wmm best-effort aifsn 7
nx9500-6C8809(config-radio-qos-test)#wmm voice txop-limit 1
nx9500-6C8809(config-radio-qos-test)#show context
radio-qos-policy test
 admission-control voice max-airtime-percent 9
 admission-control voice reserved-for-roam-percent 8
 accelerated-multicast stream-threshold 15
Related Commands
no (schedule-policy-config-mode-commands)
Reverts or resets 802.11e/wireless multimedia settings to their default
