Configures the activation-criteria (run-criteria) that triggers dynamic activation of DHCP service running on a redundancy device
In a managed wireless network, when the primary, active DHCP server fails (is unreachable), network clients are unable to access DHCP services, such as new IP address leasing and renewal of existing IP address leases. In such a scenario, the activation-criteria, when configured, triggers dynamic activation of the secondary DHCP server, allowing network clients to continue accessing DHCP services. The implementation provides activation-criteria options specific to a RF Domain, cluster setup, and a VRRP (Virtual Router Redundancy Protocol) master/client setup.
dhcp-server activation-criteria [cluster-master|rf-domain-manager|vrrp-master]
dhcp-server | Enables dynamic activation of the DHCP server, running on a redundancy device, based on the activation criteria specified |
activation-criteria [cluster-master| rf-domain-manager| vrrp-master] | Configures the activation criteria. Specify one of the
following options as the activation criteria:
rfs4000-229D58(config-dhcp-policy-test)#dhcp-server activation-criteria rf-domain-manager
rfs4000-229D58(config-dhcp-policy-test)#show context dhcp-server-policy test dhcp-server activation-criteria rf-domain-manager rfs4000-229D58(config-dhcp-policy-test)#
rfs4000-229D58(config-dhcp-policy-test)#no dhcp-server activation-criteria
no (dhcpv4-server-policy-config) | Removes the DHCP service activation criteria configured on this DHCP server policy |
