force (meshpoint-config)
Forces formation of sub-optimal paths through the meshpoint‘s root node.
As per legacy behavior, non-root devices under the same root, communicated by forming direct
paths through the network. This option allows non-root devices, within the meshpoint, to
communicate by forming paths through the root node.
- Access Points: AP5010, AP310i/e, AP410i/e, AP505i, AP510i, AP510e, AP560i, AP6522, AP6562, AP7161, AP7502,
AP8533.
- Service Platforms:
Syntax
force [peer-paths-through-root|peer-paths-with-root]
Parameters
| force |
meshpoint root node. |
| peer-paths-through-root |
Forces non-root devices to communicate by forming
sub-optimal paths through the root node. This option is disabled by default. |
| peer-paths-with-root |
sub-optimal paths with the root node. Does not allow formation of ad-hoc
peer-to-peer paths. This option is disabled by default. |
nx9500-6C8809(config-meshpoint-test)#force peer-paths-through-root
nx9500-6C8809(config-meshpoint-test)#show context
meshpoint test
meshid test
beacon-format mesh-point
control-vlan 25
security-mode none
no root
