mac-authentication
      Enables MAC authentication. When enabled, the system uses
         cached credentials (RADIUS server lookups are skipped) to authenticate clients.
            - Access Points: AP5010, AP310i/e, AP410i/e, AP505i, AP510i, AP510e, AP560i, AP6522, AP6562, AP7161, AP7502,
               AP8533.
            - Service Platforms:
      Syntax
         mac-authentication [cached-credentials|enforce-always]
      Parameters
                     | mac-authentication |
                     Enables MAC authentication on this WLAN and
                        configures related parameters |
                     | cached-credentials |
                     Uses cached credentials to skip RADIUS lookups.
                        This option is disabled by default. |
                     | enforce-always |
                     Enforces MAC authentication on this WLAN. When
                        enabled, MAC authentication is enforced, each time a client logs in, even
                        when the authentication type specified (using the authentication-type
                        command) is not MAC authentication. This option is disabled by
                        default. |
         rfs4000-229D58(config-wlan-test)#mac-authentication cached-credentials
      Related Commands
                     | no (wlan-config-mode) |
                     Disables MAC authentication related parameters: Disables use of cached
                        credentials to skip RADIUS lookups, or disables enforcement of MAC
                        authentication on this WLAN. |
