radius-group
Configures RADIUS user group and enters its configuration mode
- Access Points: AP5010, AP310i/e, AP410i/e, AP505i, AP510i, AP510e, AP560i, AP6522, AP6562, AP7161, AP7502,
AP8533.
- Service Platforms:
Syntax
radius-group <RADIUS-GROUP-NAME>
Parameters
<RADIUS-GROUP-NAME> |
Specify a RADIUS user group name. The name should not exceed 64
characters. If a RADIUS user group with the specified name does not exist,
it is created. |
nx9500-6C8809(config)#radius-group testRadiusGr
nx9500-6C8809(config-radius-group-testRadiusGr)#?
Radius user group configuration commands:
guest Make this group a Guest group
no Negate a command or set its defaults
policy Radius group access policy configuration
rate-limit Set rate limit for group
clrscr Clears the display screen
commit Commit all changes made in this session
do Run commands from Exec mode
end End current mode and change to EXEC mode
exit End current mode and down to previous mode
help Description of the interactive help system
revert Revert changes
service Service Commands
show Show running system information
write Write running configuration to memory or terminal
Related Commands
no
Removes an existing RADIUS group |
For more information on RADIUS user
group commands, see
RADIUS Policy.
