Enables monitoring of critical resource and primary port links. It also configures the action taken in case a critical resource goes down or a primary port link is lost.
Access Points — AP 6522, AP 6532, AP 6562, AP 7161, AP 7502, AP-7522, AP 7532, AP-7562, AP7632, AP7662, AP-8432, AP-8533
monitor [critical-resource|primary-port-link-loss] action no-root
                         critical-resource  |
                         Enables critical resource down event monitoring  |
                         primary-port-link-loss  |
                         Enables primary port link loss event monitoring  |
                         action  |
                         The following are common to all of the above:
nx9500-6C8809(config-profile-AP71XXTestProfile-meshpoint-test)#monitor critical-resource
action no-root
         nx9500-6C8809(config-profile-AP71XXTestProfile-meshpoint-test)#show context meshpoint-device test name test monitor critical-resource action no-root nx9500-6C8809(config-profile-AP71XXTestProfile-meshpoint-test)#
| no (meshpoint-device-config) | Disables monitoring of critical resource and primary port links. |
