Configures the trustpoint assigned for validating a CMP auth Operator
A certificate links identity information with a public key enclosed in the certificate.
A CA is a network authority that issues and manages security credentials and public keys for message encryption. The CA signs all digital certificates it issues with its own private key. The corresponding public key is contained within the certificate and is called a CA certificate. A browser must contain the CA certificate in its Trusted Root Library so it can trust certificates signed by the CA's private key.
Depending on the public key infrastructure, the digital certificate includes the owner's public key, the certificate expiration date, the owner's name and other public key owner information.
Each certificate is digitally signed by a trustpoint. The trustpoint signing the certificate can be a certificate authority, corporation or individual. A trustpoint represents a CA/identity pair containing the identity of the CA, CA-specific configuration parameters, and an association with an enrolled identity certificate.
Certificates/trustpoints used in this command should be verifiable as existing on the device.For information on configuring trustpoints on a device, see trustpoint (device-config-mode).
trustpoint [cmp-auth-operator|https|radius-ca|radius-server] <TRUSTPOINT-NAME>
| trustpoint | Assigns an existing trustpoint to validate CMP auth operator, client certificates, and RADIUS server certificate |
| https | Assigns an existing trustpoint to validate HTTPS requests |
| cmp-auth-operator | Assigns an existing trustpoint to validate CMP auth operator Once validated, CMP is used to obtain and manage digital certificates in a PKI network. Digital certificates link identity information with a public key enclosed within the certificate, and are issued by the CA. Use this command to specify the CMP-assigned trustpoint. When specified, devices send a certificate request to the CMP supported CA server, and download the certificate directly from the CA server. CMP supports multiple request options through for device communicating to a CMP supported CA server. The device can initiate a request for getting the certificates from the server. It can also auto update the certificates which are about to expire.  |
| radius-ca | Assigns an existing trustpoint to validate client certificates in EAP |
| radius-server | Assigns an existing trustpoint to validate RADIUS server certificate |
| <TRUSTPOINT-NAME> | The following keyword is common to all of the above parameters:
nx9500-6C8809(config-profile-testNX9500)#trustpoint cmp-auth-operator test nx9500-6C8809(config-profile-testNX9500)#show context profile nx9000 testNX9500 no autoinstall configuration no autoinstall firmware crypto ikev1 policy ikev1-default isakmp-proposal default encryption aes-256 group 2 hash sha ........................................................... service pm sys-restart router bgp trustpoint cmp-auth-operator test nx9500-6C8809(config-profile-testNX9500)#
| no | Removes trustpoint-related configurations |
