use (other-cmp-related-commands)
Applies a crypto CMP policy to a device. Once CMP enabled, the device automatically requests for a certificate from the CA server and installs it. After applying the CMP policy, commit and write the change to memory. This is needed to apply this configuration across reboots.
To apply a CMP policy on a device, navigate to the device‘s config-device mode and execute the use > crypto-cmp-policy> <CRYPTO-CMP-POLICY-NAME> command.
Syntax
use crypto-cmp-policy <CRYPTO-CMP-POLICY-NAME>
Parameters
cmp-policy <CRYPTO-CMP- POLICY-NAME>
Applies an existing crypto CMP policy on this device. When associated with a profile, the crypto CMP policy is applied to all devices using the profile.
  • <CRYPTO-CMP-POLICY-NAME> – Specify the crypto CMP policy name. Should be existing and configured.
ap6522-D8273A(config-device-00-11-3F-D8-27-3A)#use crypto-cmp-policy CMP
ap6522-D8273A(config-device-00-11-3F-D8-27-3A)#commit
