country
Configures a wireless client filter based on the country name
Syntax
country [any|contains|exact|not-contains]
country [any|exact <WORD>|contains <WORD>|not-contains <WORD>]
Parameters
country
Specifies a wireless client filter based on how the ‘country‘ name, returned by the RADIUS server, matches the provided expression. Select one of the following options: any, contains, exact, or not-contains.
any
No specific country associated with this user-defined role. This role is applied to any wireless client from any country (no strings to match). This is the default setting.
contains <WORD>
The role is applied only when the country name, returned by the RADIUS server, contains the string specified in the role.
  • <WORD> – Specify the string to match (this is case sensitive, and is compared against the country name returned by the RADIUS server). It should contain the provided expression.
exact <WORD>
The role is applied only when the country name, returned by the RADIUS server, exactly matches the string specified in the role.
  • <WORD> – Specify the exact string to match (this is case sensitive, and is compared against the country name returned by the RADIUS server). It should be an exact match.
not-contains <WORD>
The role is applied only when the country name, returned by the RADIUS server, does not contain the string specified in the role.
  • <WORD> – Specify the string not to match (this is case sensitive, and is compared against the country name returned by the RADIUS server). It should not contain the provided expression.
nx9500-6C8809(config-role-policy-test-user-role-testing)#country exact America
nx9500-6C8809(config-role-policy-test-user-role-testing)#show context
 user-role testing precedence 10
  authentication-type eq kerberos
  ap-location contains office
  captive-portal authentication-state pre-login
  city exact SanJose
  company exact Examplecompany
Related Commands
no
Removes the country name configured with this user-defined role
