Configures the antenna ID on an AP560h model access point profile and device. This command allows you to select the internal antenna modes.
The ExtremeMobility AP560h access point is a dual-radio access point, with eight, internal Wi-Fi antennas, supporting two internal antenna modes: 30 degree and 70 degree.
To enable the AP560h radio, configure the country code, map a WLAN to the radio, and configure the internal antenna mode as '30 degree' or '70 degree'.
antenna-id internal [internal-560h-30|internal-560h-70|default]
| antenna-id | Allows you to configure the functional mode for the AP560h access point's internal antennas. |
| internal | States the antenna is internal. |
| internal-560h-30 | Configures the internal antenna mode as 30 degree. |
| internal-560h-70 | Configure the internal antenna mode as 70 degree. |
| default | Sets the antenna mode to default. In this mode, no the antenna-mode is not specified and the radio is disabled. You must set the antenna mode to either 30 degree or 70 degree to turn-on the radios. |
| Software Mode 1 |
| Software Mode 2 |
| Software Mode 3 |
nx9500-6C8809(config-profile-ap560h)#antenna-id internal internal-560h-70
nx9500-6C8809(config-profile-ap560h)#show context include-factory | include antenna-id antenna-id external group-1 default antenna-id external group-2 default antenna-id internal internal-560h-70 nx9500-6C8809(config-profile-ap560h)#
| no | Reverts the antenna mode to default on the selected AP560h profile and device. |
