11axSupport
Enables the 802.11ax mode on the radio. The IEEE 802.11ax standard is the latest in the IEEE 802 set of protocols designed for managing wireless networks. It succeeds the 802.11ac standard and adds improvements in terms of scalability and flexibility. The 802.11ax capable APs can support more clients and provide support for next-generation applications.
Extreme Networks AP5xx model access points are 802.11ax capable APs. By default 802.11ax mode is disabled. Use this command to enable the 802.11ax mode.
Syntax
None
Parameters
None
ap510-133B38(config-device-94-9B-2C-13-3B-38-if-radio1)#11axSupport
ap510-133B38(config-device-94-9B-2C-13-3B-38-if-radio1)#show context
 interface radio1
  11axSupport
Related Commands
no (radio-interface-config-command) Disables 802.11ax mode on the selected radio
