Configures this meshpoint as the root meshpoint. Root meshpoints are generally tied to an Ethernet backhaul for wired connectivity. By default this option is disabled.
root
None
nx9500-6C8809(config)#meshpoint root nx9500-6C8809(config-meshpoint-root)#
nx9500-6C8809(config-meshpoint-root)#meshid test
nx9500-6C8809(config-meshpoint-root)#root
nx9500-6C8809(config-meshpoint-root)#security-mode eap
nx9500-6C8809(config-meshpoint-root)#commit
nx9500-6C8809(config-meshpoint-root)#show context meshpoint root meshid test beacon-format mesh-point control-vlan 1 security-mode eap root nx9500-6C8809(config-meshpoint-root)#
nx9500-6C8809(config)#meshpoint no-root nx9500-6C8809(config-meshpoint-no-root)#
nx9500-6C8809(config-meshpoint-no-root)#meshid test
nx9500-6C8809(config-meshpoint-no-root)#security-mode eap
nx9500-6C8809(config-meshpoint-no-root)#show context meshpoint no-root meshid test beacon-format mesh-point control-vlan 1 security-mode eap no root nx9500-6C8809(config-meshpoint-no-root)#
nx9500-6C8809(config)#ap81xx B4-C7-99-71-17-28
nx9500-6C8809(config-device-B4-C7-99-71-17-28)#meshpoint-device no-root nx9500-6C8809(config-device-B4-C7-99-71-17-28-meshpoint-no-root)#
nx9500-6C8809(config-device-B4-C7-99-71-17-28-meshpoint-no-root)#show context meshpoint no-root meshid test beacon-format mesh-point control-vlan 1 security-mode eap no rootnx9500-6C8809(config-device-B4-C7-99-71-17-28-meshpoint-no-root)#
nx9500-6C8809(config-device-B4-C7-99-71-17-28-meshpoint-no-root)#root
nx9500-6C8809(config-device-B4-C7-99-71-17-28-meshpoint-no-root)#show context meshpoint no-root meshid test beacon-format mesh-point control-vlan 1 security-mode eap root nx9500-6C8809(config-device-B4-C7-99-71-17-28-meshpoint-no-root)#
| no (meshpoint-config) |
                         Removes the configuration of this meshpoint device as a root meshpoint  |
