schedule-policy
    Creates a schedule policy and enters its
      configuration mode. A schedule policy strategically enforces application filter policy rules
      during administrator assigned intervals.
                - Access Points — AP410i/e AP460i/e, AP505i, AP510i/e, AP560i/h, AP7522, AP7532,
                    AP7562, AP7602, AP7612, AP7622, AP7632, AP7662, AP8432, AP8533
                - Service Platforms —
                - Virtual Platforms —
                        CX9000, VX9000
    Syntax
      schedule-policy <SCHEDULE-POLICY-NAME>
    Parameters
              | schedule-policy <SCHEDULE-POLICY-NAME> |
              Specify the Schedule policy name. If a policy with the specified name does not
                exist, it is created. The name should not exceed 32 characters in length. |
      nx9500-6C8809(config)#schedule-policy test
nx9500-6C8809(config-schedule-policy-test)#?
Schedule Policy Mode commands:
  description  Schedule policy description
  no           Negate a command or set its defaults
  time-rule    Configure a time rule
  clrscr       Clears the display screen
  commit       Commit all changes made in this session
  do           Run commands from Exec mode
  end          End current mode and change to EXEC mode
  exit         End current mode and down to previous mode
  help         Description of the interactive help system
  revert       Revert changes
  service      Service Commands
  show         Show running system information
  write        Write running configuration to memory or terminal
    Related Commands
              | no |
              Removes an existing schedule policy |
