For radios 1 and 2, use the antenna-id
command to specify the antenna type used in antenna ports
1, 2, 3, and 4.Note
For radio 3, use theantenna-id
antenna ports 5 and 6. Radio3 can only function in the 'sensor'
mode.antenna-id external [group-1|group-2|group-3] <ANTENNA-TYPE>
antenna-id | Selects the antenna group to use. |
external | States the antenna is external |
group-1 | Configures the antenna type used in the group-1 antenna ports (1,
2, 3, and 4). Note: For radios 1 and 2, use the
antenna-id
ports 1, 2, 3, and 4. |
group-2 | Group 2 configuration is not applicable for the AP410e model AP. |
group-3 | Configures the antenna type used in the group-3 antenna ports (5
and 6). Note: For AP410e, antennas 5 and 6 are dual-band
concurrent sensor only. For radio 3, use the
antenna-id
mode. |
antenna-type | After selecting the
antenna group, configure the antenna-type used: The antenna types supported for group-1 and group-3 antenna ports are: ai-dq04360s, ml-2452-apa2-01, ml-2452-apa2-02, ml-2452-hpa5-036, ml-2452-hpag4a6-01, ml-2452-hpag5a8-01, ml-2452-pna5-01r, ml-2452-pta4m4-036, ml-2452-sec6m4-036, ws-ai-de07025, ws-ai-de10055, ws-ai-dq05120, and ws-ao-dq04360n. |
nx9500-6C8809(config-profile-testAP410e)#antenna-id external ? group-1 Configure the antenna id on antenna group 1 (2.4/5GHz dual band antenna) group-2 Configure the antenna id on antenna group 2 (5GHz single band antenna or 2.4GHz single band antenna) group-3 Configure the antenna id on antenna group 3 (2.4/5GHz dual band antenna on radio 3) nx9500-6C8809(config-profile-testAP410e)#
nx9500-6C8809(config-profile-testap410e)#antenna-id external group-1 ? ai-dq04360s AI-DQ04360S Dual Band, Four Input Omni, 36 Inch Cable default Internal antenna for internal SKU, auto select antenna for external SKU ml-2452-apa2-01 ML-2452-APA2-01 3dBi/4.85dBi, dual band, black ml-2452-apa2-02 ML-2452-APA2-02 3dBi/4.85dBi, dual band, white ml-2452-hpa5-036 ML-2452-HPA5-036 3dBi/5dBi, dual band, outdoor, white ml-2452-hpag4a6-01 ML-2452-HPAG4A6-01 4dBi/7.3dBi, N-type male, dual band, outdoor, white ml-2452-hpag5a8-01 ML-2452-HPAG5A8-01 ml-2452-pna5-01r ML-2452-PNA5-01R 2.4/5 GHz, Outdoor, Panel, 5 dBi, Beam Width: E-Plane: 65 degrees, H-Plane: 120 degrees ml-2452-pna7-01r ML-2452-PNA7-01R 8/12dBi 68deg Panel ml-2452-pta4m4-036 ML-2452-PTA4M4-036 4dBi/5 dBi, 4 port, dual band ml-2452-sec6m4-036 ML-2452-SEC6M4-036 DUAL POLARIZED DUAL BAND WIDE BEAM DIRECTIONAL ANTENNA WITH 36 INCH CABLE ws-ai-dq05120 WS-AI-DQ05120 DUAL POLARIZED DUAL BAND WIDE BEAM DIRECTIONAL ANTENNA WITH 36 INCH CABLE nx9500-6C8809(config-profile-testap410e)#
nx9500-6C8809(config-profile-testap460)#antenna-id external group-1 ai-dq04360s
nx9500-6C8809(config-profile-testap410e)#show context include-factory | include antenna-id antenna-id external group-1 ai-dq04360s antenna-id external group-2 default antenna-id external group-3 default antenna-id internal internal-560h-30 nx9500-6C8809(config-profile-testap410e)#
no | Removes the antenna-id configuration on the selected AP410e profile and device. |
