network (bgp-router-config)
Configures the local network IP addresses and masks. These network
addresses are broadcasted to neighboring BGP peers. You can configure a single IP address or
a range of IP addresses in the A.B.C.D/M notation.
- Service Platforms — NX9500, NX9600
Syntax
network <IP/M> {backdoor|pathlimit|route-map}
network <IP/M> {backdoor pathlimit <1-255>}
network <IP/M> {pathlimit <1-255>}
network <IP/M> {route-map <ROUTE-MAP-NAME>}
Parameters
network <IP/M> {backdoor pathlimit <1-255>|pathlimit <1-255>|route-map <ROUTE-MAP-NAME>}
| network <IP/M> |
Configures the local network‘s address in the A.B.C.D/M
format
- <IP/M> – Specify the network address.
| backdoor pathlimit <1-255> |
Optional. Configures a BGP backdoor route. After
configuring the backdoor route, you can optionally configure the as-path hop count
limit attribute for this backdoor route.
- pathlimit <1-255> – Specify the hop count limit from 1 - 255.
| pathlimit <1-255> |
Optional. Configures the maximum path limit for this AS
- <1-255> – Specify the hop count limit from 1 - 255.
| route-map <ROUTE-MAP-NAME> |
Optional. Associates a BGP route map with this local
network. When applied, the route-map values take precedence
- <ROUTE-MAP-NAME> – Specify the route map name.
nx9500-6C8809(config-profile testNX9000-router-bgp)#network 192.168.13.0/24 backdoor pathlimit 200
nx9500-6C8809(config-profile testNX9000-router-bgp)#show context
router bgp
bgp enable
asn 1
aggregate-address 116.117.118.0/24 as-set summary-only
distance bgp 200 100 200
bgp neighbor 192.168.13.99
remote-as 199
maximum-prefix 9999 80 restart 50
network 1.2.3.0/24
bgp-route-limit num-routes 10
