oauth
Enables OAuth-driven Google and/or Facebook authentication on captive portals that use internal Web pages.
To enable Google and Facebook captive-portal authentication:
  • Enforce captive-portal authentication on the WLAN to which wireless-clients associate. For information, see captive-portal-enforcement.
  • Set captive-portal Web page location to internal. For more information, see webpage-location.
  • Register your captive-portal individually on Google/FaceBook APIs and generate a client-id and client-secret. The client-ids retrieved during registration are the IDs for the WiNG application running on the access point/controller. The WiNG application uses these client-ids to access the Google and Facebook Auth APIs, and authenticate the guest client on behalf of the user.
If enabling OAuth-driven Google and/or Facebook authentication on the captive portal, use this command to configure the Google/Facebook client-ids. Once enabled, the captive portal landing page, displayed on the client‘s browser, provides the Facebook and Google login buttons.
Syntax
oauth
oauth client-id [facebook|google] <WORD>
Parameters
oauth
oauth Execute this command without the associated keywords to enable OAuth on this captive-portal. If enabling OAuth, ensure the captive-portal Web page location is configured as advanced or external.
oauth client-id [facebook|google] <WORD> Configures the client-ids retrieved from the Google and Facebook API manager portals during registration
  • facebook – Configures the Facebook API client-id (is a 15 digit entity)
  • google – Configures the Google API client-id (is a 12 digit number)
    • <WORD> – Provide the Facebook/Google client-id.
If the captive-portal Web page location is advanced or external, and you are enabling OAuth support, you need not configure the client-id. In such a scenario, the client-id is configured through the EGuest server UI and not the WiNG CLI.
Example (User Exec Mode)
nx7500-6DCD39(config-captive-portal-test2)#OAuth
nx7500-6DCD39(config-captive-portal-test2)#OAuth client-id Google xxxxxxxxxxxx.apps.googleusercontent.com Facebook yyyyyyyyyyyyyyy
nx7500-6DCD39(config-captive-portal-test2)#show context
captive-portal test2
 server host guest.social.com
  oauth
  oauth client-id Google xxxxxxxxxxxx.apps.googleusercontent.com Facebook yyyyyyyyyyyyyyy
nx7500-6DCD39(config-captive-portal-test)#
In the above example,
