Important
This feature is supported only on AP's with USB ports. Ensure the AP is using PoE+ (802.3at) power for the USB port to be enabled.
Your AP will not communicate with the ESL server with any exisiting or older versions of Imagotag configuration.ESL tags are small, battery-powered devices used by retail businesses to display information, such as product code, pricing, etc. These tags are activated, configured, and managed through an SES-Imagotag server. The tags and server communicate through an ESL communicator (a USB dongle) connected to the USB port on the WiNG AP. This communication is over the 2.4 GHz band using a proprietary RF protocol. The ESL communicator acts as a bridge between the tags and the server, using WiNG AP as an infrastructure device.
This policy enables the ESL communicator, identifies the Imagotag server host, configures the payload size, etc. Apply the policy to the AP‘s self (in case of stand alone AP) or profile context. When applied to the profile, the policy is pushed to the AP through the adopting controller.
Important
On the Imagotag server, configure the WiNG AP's ID. This enables the server identify the WiNG AP. Use theshow > iot-device-type-imagotag >
          status command to obtain the WiNG AP's ID. Refer to the Imagotag server
        configuration guide for more information.iot-device-type-imagotag-policy <POLICY-NAME>
| iot-device-type-imagotag-policy <POLICY-NAME> | Specify an IoT Device-type Imagotag policy name. If a policy by the specified name does not exist, it is created. |
nx5500-85FA27(config-iot-device-type-imagotag-policy-Default)#?
Iot Imagotag Policy Mode commands:
  channel            Configure ESL channel
  enable             Enable ESL communicator
  fcc-mode           Enable fcc compatibility mode on ESL communicator
  no                 Negate a command or set its defaults
  output-power       Maximum output power
  payload-size       Configure payload size
  server             ESL server
  ssl                Enable ssl on ESL communicator
  ssl-cn-verify      Enforce SSL Common Name attribute verification
  ssl-strict-verify  Enforce SSL strict verification
  trustpoint         Trustpoint for server CA certificate
  window-size        Configure window size
  clrscr             Clears the display screen
  commit             Commit all changes made in this session
  do                 Run commands from Exec mode
  end                End current mode and change to EXEC mode
  exit               End current mode and down to previous mode
  help               Description of the interactive help system
  revert             Revert changes
  service            Service Commands
  show               Show running system information
  write              Write running configuration to memory or terminal
You must upgrade your existing on-prem ESL server and add new parameters to theiot-device-type-imagotag-policy
          to enable a secure connection.
Ensure that your ESL server is migrated to latest version supporting outbound connection mode and encrypted communication support.| no | Deletes the specified IoT Device Type Imagotag policy |
