override-capability (bgp-neighbor-config)
Enables the overriding of capability negotiation results. This option is disabled by default.
Syntax
override-capability
Parameters
None
nx9500-6C8809(config-profile testNX9000-router-bgp-neighbor-192.168.13.99)#override-capability
nx9500-6C8809(config-profile testNX9000-router-bgp-neighbor-192.168.13.99)#show context
  bgp neighbor 192.168.13.99
   advertisement-interval 100
   allowas-in 10
   attribute-unchanged as-path
   capability orf prefix-list both
   default-originate
   description neighbor "This neighbor is an external AS neighbor"
   disable-connected-check
   dont-capability-negotiate
   ebgp-multihop 20
   enforce-multihop
   local-as 20 no-prepend
   maximum-prefix 400 50 warning-only
   next-hop-self
   override-capability
Related Commands
no (bgp-neighbor-config) Disables the overriding of capability negotiation results
