email
    Configures guest user e-mail
      notification settings. When configured, guest users can register themselves with their e-mail
      credentials as a primary key for authentication. The captive portal system provides the pass
      code for their registration. Guest users need to use their registered e-mail, mobile, or
      member ID and the received pass code for subsequent logins to the captive portal.
        - Service Platforms — NX 75XX, NX 95XX, NX 96XX, VX 9000
Syntax
      email [host|message|subject]
      email host [<IP/HOSTNAME>|<HOST-ALIAS-NAME>] sender <EMAIL-ADDRESS>
security [none|ssl|starttls] username <USER-NAME> password <PASSWORD>
      email message <LINE>
      email subject <LINE>
    Parameters
      email host [<IP/HOSTNAME>|<HOST-ALIAS-NAME>] sender <EMAIL-ADDRESS> security
              | email | Configures guest user e-mail notification
                settings |
              | host [<IP/HOSTNAME>| <HOST-ALIAS-NAME>] | Configures the SMTP server‘s IP address or hostname used
                for guest management e-mail traffic, guest user credential validation, and pass code
                reception. Optionally you can use an existing host alias to identify the SMTP server
                host.
                  <IP/HOSTNAME> – Specify the SMTP server‘s IPv4 address or hostname. <HOST-ALIAS-NAME> – Specify the host alias name (should be existing and
                    configured). Consider providing the host as an alias. A host alias is a
                    configuration item that maps the alias to a hostname. Once created, it can be
                    used across different configuration modes. Where ever used the alias is replaced
                    by the associated hostname. |
              | sender <EMAIL-ADDRESS> | Configures the sender‘s name for the guest user
                receiving the passcode required for registering their guest E-mail credentials using
                SMTP.
                  <EMAIL-SENDER> – Specify the sender‘s name (should not exceed 100
                    characters). |
              | security [none|ssl|starttls] | Configures the encryption protocol used by the SMTP
                server when communicating the pass code
                  none – No encryption used. Use if no additional user authentication is needed
                    beyond the required username and password combination.SSL – Uses SSL encryption. This is the default setting. STARTTLS – Uses STARTTLS encryption |
              | username <USER-NAME> | Configures a username unique to this SMS guest
                management configuration. After configuring the username, specify the associated
                password. Ensure that the password is correctly provided to receive the pass code
                required for registering guest user credentials with SMS.
                  <USER-NAME> – Specify the username (should not exceed 100 characters). |
              | password <PASSWORD> | Configures the password associated with the specified
                SMTP user name
                  <PASSWORD> – Specify the password (should not exceed 63 characters). |
                content |
              | message <LINE> | Configures the content of the e-mail sent to the guest
                user notifying the pass code (should not exceed 1024 characters)
                  <LINE> – Specify the message content. When entering the message, use the
                    following tags: GM-NAME – for the guest user‘s name  GM_PASSCODE – for
                      the pass code  CR-NL – to enter a new line  For example: Dear
                      GM_NAME, CR-NL your internet access pass code is GM_PASSCODE. CR-NL Use this
                      for internet access. |
              | email | Configures guest user e-mail notification subject
                line |
              | subject <LINE> | Configures the subject line of the e-mail sent to the
                guest user notifying the pass code (should not exceed 100 characters) |
      nx9500-6C8809(config-guest-management-test)#email host 192.168.13.10 sender
bob@extremenetworks.com security ssl username guest1 password guest1@123
      nx9500-6C8809(config-guest-management-test)#show context
guest-management test
 email host 192.168.13.10 sender bob@extremenetworks.com security ssl username guest1 password guest1@123
      nx9500-6C8809(config-guest-management-test2)#email message Dear GM_Guest2, CR-NL
Your internet access passcode is GM_Guest2. CR-NL Use this for internet access.
      nx9500-6C8809(config-guest-management-test2)#email subject GM_Guest2 Your internet access code
      nx9500-6C8809(config-guest-management-test2)#show context
guest-management test2
 email message Dear GM_Guest2,  CR-NL  Your internet access passcode is GM_Guest2.  CR-NL  Use this for internet access.
