ex3500-management-policy-config-commands
Table 1. EX3500 Management Policy Config Commands
Command Description
enable Configures an executive password for this EX3500 management policy
http Configures the HTTP server settings used to authenticate HTTP connection to a EX3500 switch
memory Configures the EX3500‘s memory utilization rising (upper) and falling (lower) threshold values
process-cpu Configures the EX3500‘s CPU (processor) utilization rising (upper) and falling (lower) threshold values
snmp-server Configures SNMP server settings. Once configured and applied on a EX3500 switch, the management policy controls access to the switch from management stations using SNMP.
ssh Configures the SSH server settings used to authenticate SSH connection to a EX3500 switch
username Configures a EX3500 switch user settings
no (ex3500-management-policy-config-mode) Removes or reverts this EX3500 management policy settings
