Enables one-hop away eBGP peer using loop back address. This option is disabled by default.
disable-connected-check
None
nx9500-6C8809(config-profile testNX9000-router-bgp-neighbor-192.168.13.99)#disable-connected-check
nx9500-6C8809(config-profile testNX9000-router-bgp-neighbor-192.168.13.99)#show context bgp neighbor 192.168.13.99 advertisement-interval 100 allowas-in 10 attribute-unchanged as-path capability orf prefix-list both default-originate description neighbor "This neighbor is an external AS neighbor" disable-connected-check nx9500-6C8809(config-profile testNX9000-router-bgp-neighbor-192.168.13.99)#
no (bgp-neighbor-config) | Disables one-hop away eBGP peer using loop back address |
