adopter-auto-provisioning-policy-lookup
Profile Config Commands
Enables the use of a centralized auto provisioning policy on this profile. When enabled, the auto-provisioning policy applied on the NOC gets precedence over the one applied at the site controller level. Optionally, use the ‘evaluate-always‘ option to set flag to run centralized auto-provisioning policy every time a device (access point/controller) is adopted. The device‘s previous adoption status is not taken into consideration.
This command is also applicable in the device configuration context.
Syntax
adopter-auto-provisioning-policy-lookup {evaluate-always}
Parameters
adopter-auto-provisioning-policy-lookup {evaluate-always} Enables the use of a centralized auto provisioning policy on this profile or device
  • evaluate-always – Optional. Sets flag to run centralized auto-provisioning policy every time a device (access point/controller) is adopted.
nx9500-6C8809(config-profile-test4K)#adopter-auto-provisioning-policy-lookup evaluate-always
nx9500-6C8809(config-profile-test4K)#show context include-factory | include adopter-auto-provisioning-policy-lookup
Related Commands
no Disables the application of centralized auto provisioning policy on this profile or device
