shutdown
interface-config-bluetooth-instance
Shutsdown the selected AP8432/AP8533 Bluetooth radio interface
Syntax
shutdown
Parameters
None
nx9500-6C8809(config-profile-default-ap8432-if-bluetooth1)#shutdown
nx9500-6C8809(config-profile-default-ap8432-if-bluetooth1)#show context
 interface bluetooth1
  shutdown
  mode le-beacon
  beacon pattern ibeacon
  ibeacon calibration-rssi -70
  ibeacon major 1110
  ibeacon minor 2210
  ibeacon uuid f2468da65fa82e841134bc5b71e0893e
Related Commands
no (bluetooth-inf-config-command) Reverses shutdown
