use
interface-config-ge-instance
Specifies the IP (IPv4 and IPv6) access list and MAC access list used with this Ethernet port. The associated ACL firewall inspects IP and MAC traffic flows and detects attacks typically not visible to traditional wired firewall appliances.
- Access Points: AP5010, AP310i/e, AP410i/e, AP505i, AP510i, AP510e, AP560i, AP6522, AP6562, AP7161, AP7502,
AP8533.
- Service Platforms:
use [ip-access-list in <IPv4-ACCESS-LIST-NAME>|ipv6-access-list <IPv6-ACCESS-LIST-NAME>|
mac-access-list in <MAC-ACCESS-LIST-NAME>]
Parameters
| ip-access-list
in <IPv4-ACCESS-LIST-NAME> |
Associates an
IPv4 access list with this Ethernet port. IPv4 is a connectionless protocol
for packet switched networking. IPv4 operates as a best effort delivery
method, as it does not guarantee delivery, and does not ensure proper
sequencing or duplicate delivery (unlike (TCP). IPv4 hosts can use link
local addressing to provide local connectivity.
- in – Applies the IPv4 ACL
on incoming packets
- <IPv4-ACCESS-LIST-NAME> – Specify the IPv4 access list
name (it should be an existing and configured).
| ipv6-access-list
in <IPv6-ACCESS-LIST-NAME> |
Associates an
IPv6 access list with this Ethernet port. IPv6 is the latest revision of the
IP designed to replace IPv4. IPV6 provides enhanced identification and
location information for computers on networks routing traffic across the
Internet. IPv6 addresses are composed of eight groups of four hexadecimal
digits separated by colons.
- in – Applies the IPv6 ACL
on incoming packets
- <IPv6-ACCESS-LIST-NAME> – Specify the IPv6 access list
| mac-access-list
in <MAC-ACCESS-LIST-NAME> |
Associates a MAC
access list with this Ethernet port. MAC ACLs filter/mark packets based on
the MAC address from which they arrive, as opposed to filtering packets on
layer 2 ports.
- in – Applies the MAC ACL
on incoming packets
- <MAC-ACCESS-LIST-NAME> – Specify the MAC access list name
nx9500-6C8809(config-profile-testnx5500-if-ge1)#use mac-access-list in test
nx9500-6C8809(config-profile-testnx5500-if-ge1)#use ip-access-list in test
nx9500-6C8809(config-profile-testnx5500-if-ge1)#show context
interface ge1
description "This is GigabitEthernet interface for Royal King"
speed 10
duplex full
switchport mode accessi
switchport access vlan 1
spanning-tree bpduguard enable
spanning-tree bpdufilter disable
spanning-tree force-version 1
--More--
Related Commands
| no |
Disassociates the IP access list or MAC access list from the interface |
