Specifies the number of users (client MAC addresses) that can simultaneously log on to the captive portal. This option is disabled by default.
simultaneous-users <1-8192>
                         simultaneous-users <1-8192>  |
                         Specifies the number of MAC addresses that can
                           simultaneously access the captive portal
nx9500-6C8809(config-captive-portal-test)#simultaneous-users 5
         nx9500-6C8809(config-captive-portal-test)#show context captive-portal test access-time 35 custom-auth info bob bob@examplecompany.com connection-mode https inactivity-timeout 750 server host 172.16.10.9 simultaneous-users 5 nx9500-6C8809(config-captive-portal-test)#
| no |
                         Resets or disables captive portal commands  |
