Configures this DHCPv6 server policy‘s DHCP option settings, such enterprise (vendor) ID
DHCPv6 services are available for specific IP interfaces. A pool (or range) of IPv6 network addresses and DHCPv6 options can be created for each IPv6 interface defined. This range of addresses can be made available to DHCPv6 enabled devices on either a permanent or leased basis. DHCPv6 options are provided to each client with a DHCPv6 response and provide DHCPv6 clients information required to access network resources (default gateway, domain name, DNS server and WINS server configuration). An option exists to identify the vendor and functionality of a DHCPv6 client. The information is a variable-length string of characters (or octets) with a meaning specified by the vendor of the DHCPv6 client.
option <OPTION-NAME> <0-254> [ascii|hexstring|ipv6] <1-4294967295>
| option <OPTION-NAME> | Specify a unique name for this DHCP option. The name should describe option's function. |
| <0-254> | Specify a DHCP option code for this option.
 The system allows only one code, of the same value, for each DHCP option used in each DHCPv6 server policy.  |
| ascii | Specifies the option type as ASCII (sends an ASCII compliant string to the client) |
| hexstring | Specifies the option type as a string of hexadecimal characters (sends a hexadecimal string to the client) |
| ipv6 | Specifies the option type as IPv6 address (sends an IPv6 compatible address to the client) |
| <1-4294967295> | This parameter is common to all option types.
 Each vendor should have a unique vendor ID used by the DHCP server to issue vendor-specific DHCP options.  |
nx9500-6C8809(config-dhcpv6-server-policy-test)#option DHCPServerOption1 10 ascii 50
      nx9500-6C8809(config-dhcpv6-server-policy-test)#show context dhcpv6-server-policy test option DHCPServerOption1 10 ascii 50 dhcpv6-pool DHCPv6Pool1 network 2002::/64 domain-name TechPubs sip domain-name TechPubsSIP dns-server 2002::1 nx9500-6C8809(config-dhcpv6-server-policy-test)#
| no (dhcpv6-server-policy-config) | Removes the DHCPv6 server option settings configured for this DHCPv6 server policy |
