dont-capability-negotiate (bgp-neighbor-config)
Disables capability negotiation with BGP neighbors. This is to allow compatibility with older BGP versions that have no capability parameters used in the open messages between peers. Capability negotiation is enabled by default.
Syntax
Parameters
None
nx9500-6C8809(config-profile testNX9000-router-bgp-neighbor-192.168.13.99)#dont-capability-negotiate
nx9500-6C8809(config-profile testNX9000-router-bgp-neighbor-192.168.13.99)#show context
  bgp neighbor 192.168.13.99
   advertisement-interval 100
   allowas-in 10
   attribute-unchanged as-path
   capability orf prefix-list both
   default-originate
   description neighbor "This neighbor is an external AS neighbor"
   disable-connected-check
Related Commands
no (bgp-neighbor-config) Enables capability negotiation with BGP neighbors
