interface-config-radio-instance
Configures the maximum number of wireless clients allowed to associate with this radio
max-clients <0-256>
max-clients <0-256>
max-clients <0-256> | Configures the
maximum number of clients allowed to associate with a radio, subject to the
access point‘s limit. Specify a value from 0 - 256. The default is
256. Note: The maximum number of clients supported per radio is 256. On
the AP, the maximum number of clients supported is 500. If both radios
are up, the total number of wireless clients that can associate with the
AP is 500.
nx9500-6C8809(config-profile-510TestProfile-if-radio1)#max-clients 100 nx9500-6C8809(config-profile-510TestProfile-if-radio1)#show context interface radio1 description "Primary radio to use" channel 1 data-rates b-only beacon period 50 beacon dtim-period bss 1 5 beacon dtim-period bss 2 2 .............................................. beacon dtim-period bss 12 5 beacon dtim-period bss 13 5 beacon dtim-period bss 14 5 beacon dtim-period bss 15 5 beacon dtim-period bss 16 5 antenna-gain 12.0 guard-interval long aggregation ampdu tx-only aeroscout forward ekahau forward ip 172.16.10.1 port 3 antenna-mode 2x2 antenna-diversity max-clients 100 airtime-fairness prefer-ht weight 6 lock-rf-mode extended-range 15 antenna-downtilt nx9500-6C8809(config-profile-510TestProfile-if-radio1)#
no (radio-interface-config-command) | Resets the maximum number of wireless clients allowed to associate with a radio |
