edge-vlan
bridge
Enables the edge VLAN mode. In the edge VLAN mode, a protected port does not forward traffic to another protected port on the same wireless controller or service platform. This feature is enabled by default.
Syntax
edge-vlan
Parameters
None
nx9500-6C8809(config-profile-default-rfs4000-bridge-vlan-1)#edge-vlan
Related Commands
no Disables the edge VLAN mode
